Use the following procedure to view the online, offline and root certificates in the local store.
- Select Certificate.
- Select the Certificate Store tab.
Certificate Store Field Descriptions
Use the data in the following table to use the Certificate Store tab.
Name |
Description |
CommonName |
Specifies the Common Name of the Certificate Authority issuing the Digital Certificate. |
Type |
Specifies the certificate type. |
VersionNumber |
Specifies the version number of the certificate for the subject as issued by the Certificate Authority. |
SerialNumber |
Specifies the serial number of the certificate for the subject as issued by the Certificate Authority. |
IssuerName |
Specifies the name of the issuer of the certificate for the subject as issued by the Certificate Authority. |
ValidStartPeriod |
Specifies the start date of the validation period of the certificate for the subject as issued by the Certificate Authority. |
ValidEndPeriod |
Specifies the last date of the validation period of the certificate for the subject as issued by the Certificate Authority. |
CertificateSignatureAlgorithm |
Specifies the algorithm used for the signature of the issuer on the certificate for the subject as issued by the Certificate Authority. |
CertificateSignature |
Specifies the signature of the issuer on the certificate for the subject as issued by the Certificate Authority. |
Subject |
Specifies the details of the subject on its certificate as issued by Certificate Authority. |
SubjectPublicKeyAlgorithm |
Specifies the algorithm used to generate the subject's public key for the certificate issued by the Certificate Authority. |
SubjectPublicKey |
Specifies the public key of the subject used for Certificate Signing Request. |
HasBasicConstraint |
Specifies whether certificate contains basic certificate constraint. |
HasKeyUsage |
Specifies whether certificate contains basic key usage constraint. |
IsCa |
Specifies if the certificate is a CA certificate or not. |
KeyUsage |
Specifies the purpose of the key used in the certificate. It is
represented in the form of bits as follows:
Status |
Specifies the status of the certificate. |
Installed |
Specifies whether the certificate is installed or not. |
CdpUrl |
Specifies the CDP URL present in the Digital Certificate Extensions field. |
OscpUrl |
Specifies the OCSP URL present in the Digital Certificate AIA field. |
ExtendedKeyUsage |
Indicates the purpose for which the key is used in addition to or in place of the basic purposes indicated in the key-usage field of the certificate. |
CaFileName |
Specifies the certificate file obtained offline from the Root Certificate Authority. |
